Question on a residential overhead service riser???
jango
We have a scenario where the 200A meter panel needs to be over some distance from where the riser/weatherhead will be. The 1 1/2" rigid riser will have two 90's and I'll need to use two lenghts of pipe. My question is, is there anything wrong with joining the two pipes with a threadless waterproof rigid compression coupling??? Thanks for your input.
