In regards to cable pulling calculations, when calculating the sidewall pressure I found 3 different equations that vary based on the conductor configuration in the conduit ie)
one conductor --> normal equation
three single conductors --> cradled configuration equation
three single conductors --> triangular configuration equation
my question is, what would the equation be for four single conductors in a conduit, complex configuration?
(complex configuration is the term used for four single conductors in a conduit while calculating weight correction factor)
I could not find anything anwhere about this. What I did temporarily is use the sidewall pressure equation for three single conductors, cradled as I put in some parameters and found this equation to yield the worse case sidewall pressure.
thanks
thanks
