Bang
- Northern Virginia
What's the method some of you use to align multiple conduits for a knockout? Let's say for both even and uneven stubs from a messed up concrete pad pour.....
We would often stub all the conduits up to the same height and get a square cut rectangle of cardboard. Hold the cardboard tight to the wall and tap with a hammer above each conduit and use that as a template to put the holes in the panel.
Mount a piece if strut to the wall and straigten the pipes the best u can and strap them in. Then pick up the panel place it on top of the pipes, center and level the panel and trace them out
Understandable, but what if you were installing a panel with multiple conduit runs deriving from the top of this new panel?
