kwired
Electron manager
- NE Nebraska
Do you understand if you have 62 on the high voltage side you should have near 71 on the low voltage side of the transformer?Well I guess I should go check the transformer and all the connections. I still dont understand how the line side could be reading so much higher though. The buck booster is wired: Whip from bed to booster, booster to disconnect, disconnect to main panel. Why am I getting that reading above disconnect? Boy this gets confusing......
Im going down their now and will check everything and get a few more readings and report back.
If you have closer to 100 something is malfunctioning or there is additional load somehow connected and it is flowing thru the point being measured.
