Raceway Application
Nec does not require mc to be supported and secured where ran through sheetrock anf consealed cotrect?
Incorrect unless it's fished in a finished building or no longer than 6' in an accessible ceiling. See 330.20(D)
Yes that is what i was referring to. A wall already covered meaning you will not have to uncover tear down sections of sheet rock
I'm with Roger on this one. The thread is about new construction, if you meant in existing construction, which I am sure you did, then you should have stated that.
