- Placerville, CA, USA
- Retired PV System Designer
California Energy certification can be audited up to a year later, yes?
It's also unrealistic to think that you'd have to wait 11 months after a business was up and running to get a call telling that you did something wrong.
JAP>
You must live in a fantasy world.I have been on school jobs, for example, where the work was done in phases over many months and the engineering inspection only happens once at the end. It isn't that there were no inspections prior, just not the engineering inspection.
It's not that way at airports. The NEC is used as a reference, but it is not the standard that is enforced. It's a federal job and they have their own specs. I think the OP is in a situation where a new referee is calling a foul that was not called in the past.I must,seeing as how I've never had to go back to one of my projects a year or more after I finished the job to fix a code violation I wasn't made aware of before I left.
JAP>
90.2 of the NEC also states that it covers these installations in the United States.
The NFPA is a private organization and cannot tell us where the NEC applies. It only applies to areas that have adopted it.
I am also curious, has anyone here EVER found a jurisdiction described in 90.2 that doesn't adopt the NEC? And I don't mean just the current version, but some version.
That is correct and so am I. http://www.gsa.gov/portal/content/101288
Legally, however, buildings built on federal property are exempt from state and local building codes. Notwithstanding, it is GSA’s policy to comply with state and local building codes to the maximum extent practicable.
