jumper
- 3 Hr 2 Min from Winged Horses
http://www.inspectpa.com/forum/forum.php
Linky no worky.
Solly Charlie about the link not working!......You can do a search for
" inspectpa.com ", and seek the Forum......PM me if you cannot locate
it!......I'll try to do better on this esteemed Forum
Thank you for fixing the non-functional link!.....Yes, by all means, ...go harrass Chris K. !
IBC does not apply!......This is under the IRC, `06 Edition....Refer to Table E3701.4.
Knowing this, what would be your code based position?.....Please play along &
offer up a postion.
Chris K. needs no extra harassment. He has to live with himself already.maybe he go harass Chris K.![]()
I don't know how perfect a sealed slab is esp. if there are penetrations.
One piece of uf is not a big deal.
I agree with that, I usually have a part roll of 12/2 in the truck for the occasional need of it even though I hate working with it.
A little THWN is not a big deal either and more likely to already be on my truck than some UF.
Cables usually pull harder through conduits than individual conductors. If the only purpose is a sleeve that is one thing but why not make it a complete raceway if there is much more than 10 feet, and not a straight drop down a wall or something similar? JMO.
The application is for a new single family dwelling......GFCI rated
conductors installed in a pvc raceway, going to a Kitchen Island,
More than that also-- it would mean locating the pipe exactly in the right spot and probably having to add a jb. Not a good idea. I will pull uf any day then try and do that.Obviously you could run conduit all the way but in many case that will be more time and material.
