paul renshaw
- Cordova, Maryland
When you install a GEC in a metal conduit, the conduit must be bonded on both ends. If you have a metal (emt) conduit run, that contains an EGC, that changes over to non-metallic flex at the end(say connection to a machine), would the conduit need to be bonded on both ends? Is there a code requirement pertaining to this? I recently have seen some installations like this and this question arose. Paul
