electricmanscott said:This is why I just run a #6 and install a 50 amp breaker and receptacle...too much reading otherwise.![]()
That is fine in the "real world" and probably provides a better installation for your customer. But what is the correct answer on an examination that asks "what is the minimum ampacity of a conductor installed for a 12KW range?" You should be aware when you are doing more than the minimum required.
