Does the rapid shutdown requirement apply to a system that operates at under 30v? Scenario off-grid cabin with utility hookup Utility feeding electrical panel and inverter feeding a seperate stand alone "emergency circuit panel"
- 800w 12v panels in parallel, max open string voltage 22v (roof mounted)
- PV Disconnect
- GFPD
- 12v battery bank 1300ah with disconnect
- 3500w (12v) single phase 120v inverter tied to seperate panel powering critical circuits. (Water line heater, well pump, lighting)
- All UL equipment, breakers, wiring, and piped according to NEC
