skindalooch
- Pennsylvania
Is it permissable to re use an existing feeder for a sub panel that is currently #4 AL SE cable (2 insulated conductors with an un insulated concentric wire)? It is an older installation and the main panel is in the garage. The sub panel is located in the basement of the main dwelling unit. The 2 buildings are separated by a breezeway. It would be alot of damage to finihes of the house to install a new ser or other suitable 4 wire cable. I need to replace both the main and the sub panel as they have fuses as ocp and the homeowners insurance wants replaced. Would it be permissable to install an isolated bar for the neutrals in the sub panel and install a ground bar in the can bonded to a cu water pipe or a new rod electrode? Im not sure when or if the existing installation ever met requirements of NEC or if it can be grandfathered.
