inspector23
- Temecula, CA
I just finished a test, and I am not sure of the answer to this question.
This concerns a 277/480V panel. What should the volt meter register when I place the leads as follows?
Line 1 to ground
line 2 to ground
line 3 to ground
across phases, ie;
line 1 to line 2
line 2 to line 3
line 1 to line 3
Is is possible to get 120v from any of these lines?
I think the line to ground voltage on each line should read 277V. I also think any two lines would read 480V across them.
I do not believe it is possible to get 120V from this system.
I would really appreciate a speedy response, especially if you know of anywhere I can find this info on the internet. You know, a picture being worth a thousand words and all.
Thanks for your help -
Mike
Line 1 to ground
line 2 to ground
line 3 to ground
across phases, ie;
line 1 to line 2
line 2 to line 3
line 1 to line 3
Mike
