rambojoe
- phoenix az
- Wireman
ok. I really tried to find my answer but web searches only brings up formulas that involve "on paper" properties if you will- as in conductor length, cross section area and temp and such. bear with me because I genuinely want to elevate my status from a mere pipe bending "mechanic.
the question is resistance of conductors and how to measure it on the job from load center to, say, light pole base 185' away (with ballast leads disconnected). on the job im sure I could play around with my meter and find my answer but if I spent a few hours educating myself it would be followed with the foreman asking "what the heck are you doing?!"
I can use my ammeter and figure out total power and amps easily but id like to know the ohms of 2 wires w/o all the length and diam. formulas.
so...using ohs law, I should be able to measure E & I at the loadcenter and compare at the light pole base (except with the ballast isolated I cant get I) and find resistance. right? or is simply using the multi meter between the conductors what I want?
Im sorry if im over thinking this...thank you for reading. Again,just looking for a quick way to find resistance of two conductors on the job....
