mbrooke
Batteries Included
- United States
- Technician
I don't think you're reading that right. The way I read it, only a gennie with twist lock recept' is required to have GFCI 15 & 20A receptacles... but if an interlock (neither mechanical or electrical is specified) defeats their availability while the twist lock is in use, GFCI is not required. If no twist lock, no GFCI is required.
IOW, for any portable generator up to 15kW with a 125/250V twist-lock receptacle, all 15- & 20A 125V receptacles must either be GFCI-protected or unusable while the twist-lock is in use.
That was what I said... a twist lock will force a GFCI (ok not always
The interlock is just strange. I cant see how it will make anything safe. A tool plugged into a 120 volt outlet is just as much of a risk whether or not a twist lock is in use.
