Re: Receptacle at service panel
Originally posted by infinity:
I think it is based on convenience of the service installer when trying to comply with Article 527.
527.4(D) and 527.6
Is this in the 2002 NEC?
Yes, it is in 2002NEC
The statements member #60 made in regards to convenience an articles 527.4(4) and 527.6 in the NEC 2002 "best explain" why you see the receptacle by the service panel in most homes.....good call on your part and glad you mentioned this.
What does Article 527 have to do with this question? Isn't 527 for temporary installations? [/QUOTE]
Well, in the areas that we work, we will set the service on a new home as soon as we can to get the power turned on by the Utility Co.
This is so we will have temporary power for running drills, saws, etc., etc. and not have to run generators.
Since the service is being used as temporary power at this point, we must comply with Article 527.
So, at this point, it is just easier and quicker to mount the (GFCI protected) receptacle(s) next to the loadcenter.
We are doing a number of large custom homes right now that have the 20amp Laundry(washer), a 20amp outdoor, (3) 20amp bathroom, and (1) 15amp sump pump circuts all energized for 'temporary power'.
Now,
Jim and Allen and the other guys in their Florida area don't have to worry about this, since they can't get the power turned on until
after their final electrical inspection.
edit: tricky quotes
[ May 13, 2005, 08:50 PM: Message edited by: luke warmwater ]
