I've seen dozens of failed backstab connections, but always where the circuit connection is made through the receptacle. I use backstabs for receptacles and switches, but the circuit connections are always through wagos or wire nuts. , no feed throughs.
Which city requires this? Is it recommendation by the inspector or it is a city rule?Most cities here in the Bay Area require that all connections be pigtailed
Is a wire nut a better connection than a wire wrapped around a screw? If you pigtail everything that is all you are saying.
I pigtail and wrap screw everything. I don't like the wagos or back stabbing, unless it is repair work, the wires are short and I can not get my fingers in the box to do a wire nut job.
All that I've worked in. Since it's not NEC required, I assume it's a local ordinance. I just do it automatically now, as I find it makes trim out much faster.
Might make trim out faster, but you still spent the time to do it, just not at trim out.All that I've worked in. Since it's not NEC required, I assume it's a local ordinance. I just do it automatically now, as I find it makes trim out much faster.
How much torque is in a hypress crimp connection?Why is the NEC implementing a new section 110.14 (D) installation torquing requirements? Can anyone tell me how much torque the backstabbing springs have?
I usually find I am being pushed more at rough in then at trim out, because they are trying to get drywallers in ASAP. So I have more time at trim out to make all those connections.Really? Wow, I would never have known. Thanks!
No. Pigtailing eliminates the use of the receptacle as a connector. The screws are incidental. Using a receptacle as a connector makes for two points of failure, and the material connecting the screws usually gets very hot when one screw gets loose and the circuit is carrying a lot of current.
I don't think I have ever seen a burnt receptacle that was pigtailed. I have two samples of burnt receptacles. Both used the screws, they weren't back stabbed. Neither were pigtailed and both used the receptacle as a connector.
I have seen this many times. That's reason enough for me to pigtail all my receptacles.
If you are one of those that the AHJ ants those connections made at rough in, that is unfortunate I guess.
Not saying there aren't ever some of those pressures at trim out for me, but the majority of switches and receptacles are usually installed before the cabinets, trim, flooring, etc. are completed. What I am being pushed on at the end of the project is connecting appliances, maybe hanging certain fixtures, waiting for kitchen cabinets/counters/backsplashes before I can finish some items in that particular room. I often have majority of what I don't have to wait for someone else installed fairly soon after painting is done, but before flooring, trim, (sometimes trim is in progress at same time) cabinets are installed. I still clean up after myself, but if done at this stage I don't have to be as particular with cleanup as I would if floors were finished.That interests me because I've always felt more rushed on trimout. Homeowner has lost all patience due to unreliable tradesmen dragging it out, time running out on construction loan, need to move out of existing residence, etc.
Also on rough-in I have some control over how much I do, leave service entrance till later if necessary etc. But on trim-out there is no almost done, its either done or it isn't
That is my guess.. folding the wire back in puts so much stress on the back stab that they often failed.I'd bet strain from pushing device into the box had some to do with that change.
UL used to allow #12 wire on these receptacles but later changed the listing to only allow 14 gauge. They had to re-tool so that nobody could push a 12 awg in the backwire area.
I just fixed on the other day where the owner replaced receptacles with pressure plate terminations (like most current GFCI receptacles use). Apparently didn't get one of them tight enough. It failed shortly after they started using a window air conditioner on a downstream outlet.
I have to agree that some you find on receptacle devices seem to suck, yet there are similar terminations on circuit breakers, contactors, etc that are just fine.I'm not completely sold on pressure plate connections. Google has several pictures of burnt GFCI's with no load connections, and they all looked like pressure plate connection failures.
Do you remember when that changed and why it was just #12?
