p real
- Fort Collins, CO
Hmmm... no need to comdescend.. perhaps you can definitively explain how wires move themselves out of an outlet then...
As stated above, when properly done, either will be as good as the other. In the old days, we back stabbed them all, no problems.[/QUOTE]
I'm guessing 99.9% of those failures were where the receptacle was used as a feed through device or had a heave load connected?
I have never done much service work but have run across more screw connection failures than back wiring failures. Most of the failures were receptacles used as feed through devices or had a heavy load (space heater) connected.
All of the projects I work on get back wired but always pigtailed. In the 31+ years I have been in business I have never had a call back from a failed connection.
I agree about pigtailing. That is the best way to connect a device. I still hate backstabbing. I have seen too many problems with stabbing. As someone else mentioned, the high grade devices you can stab and still tighten screws are excellent. A little faster and still a good tight connection. I have worked in old houses from the 1920's or 30's with receptacles still working OK that had screw connections. I have seen stabs fail in less than a year, though some do hold out longer. As you say, part of it depends on the load. Vibration is a big issue too, if a building is subject to it from any source. A hair dryer, space heater or microwave will burn out a stabbed device in no time.
My brother had issues with a lot of receptacles in his house. They were all Slater, stab type with no screws at all. I replaced them all with standard grade, pigtailed and used screws to connect. That was over 10 years ago and he hasn't had a problem since then.
Yes, where they were installed correctly. I too have seen more problems with screw connections than back stab.
I got a big smile when I read this because it reminded me how anal I used to be about stuff. Totally useless stuff, like not having two different colour wire nuts in a j box.Here is another issue many electricians would fight to the death over yet I use all methods. It depends on my mood, the job specs, the time I have etc.![]()
For clarification, in post number two I am not talking about back stab type devices. With that said, I agree that back stabbing is not always bad, I have devices that were back stabbed in a home that have been in place since the late 70's with no problems.
Roger
Not the case, the kitchen outlets carried a micro wave, a coffee maker, refrigerator, and assorted counter top appliances including a fryer at times with no problems to date.They probably never carried much load. I bet very few hair dryers, space heaters or microwaves.
Roger
I may be wrong but I think they are Leviton, they are in a home I have in FL. I replaced a few of them due to the contact tension (worn out) but no problems with the wiring connections.Do you recall the brand of receptacles? Maybe there is a better brand out there with better stabs. If so, I haven't seen it in NC.
Dennis, you are correct, the spec grade and HG are not back stab devices, for a comparison they are no different than a SQ D QOB breaker connection.Now the commercial units like hubble may be a different animal but I don't consider that a backstab.
Was doing custom homes in the 70's and can't begin to tell you how many receptacles we backstabbed and how few calls, if any, that we ever got about an issue with them.John, I am surprised to hear this. I did electrical work in the mid 70's for 2 years and saw lots of problems with stabs then, some from our own work. Most of my bosses then taught me to stab; a few old timers kicked my butt for it. I was a young squirt, just learning. We made a fair number of warranty calls and found stabbed receptacles and switches at the heart of the problem. I resolved then that I would quit stabbing forever (unless the technology improved). I did other work and came back to electrical work in 95. Still found similar issues. Then the stab connectors in can lights were coming out. I & severl others would cut them out and use wirenuts. Someone convinced me to give them a fair trial and I was amazed how well they worked. I met an Ideal rep at a supply house and asked him about that, telling how much trouble I'd seen wth stabbed devices. He'd heard it all before. He said the device makers could somehow get away with poor quility connections and blame it on the installer. But they specialize in connectors and could not take that risk. They tested and retested their connectors til they got them right. I am fully OK with them now. I doubt I will ever be OK with devices. I still see them as inviting trouble.
BTW, I assume we saw largely the same brands? In the 70's in this region, we largely saw Circle F. Recent years; Hubbell, P&S & Leviton are the most common. If you had other brands, better made, that would explain a lot. My brother's house in Oregon had Slater receptacles, stab only type. I didn't recall Slater devices before then. I knew them as the maker of nail up plastic boxes.
Have there been engineering improvements in backstabs since the bad old days? I've read one old hand saying that he has fewer problems with new ones. On the other hand maybe they simply haven't had time to fail yet. It shouldn't be an impossible engineering job to capture and clamp a wire reliably.
