ryan_618
- Salt Lake City, Utah
iwire said:Good point. :grin:
Takes a big wire nut.
Would you put tape on it? LOL
And you are entitled to be mistaken with regard to the use of the word "pigtail."iwire said:No need to be sorry, you?re entitled to be mistaken. . . . It happens the very method I have come up with to comply with those code sections without using a wire nut I also call a pigtail.![]()
I do. This is from the "McGraw-Hill Dictionary of Scientific and Technical Terms":iwire said:Do you have an official definition of pigtail?
A wiring method that puts three wires under a wire cap and runs one to the screw would fit this definition. A wiring method that loops a wire around a screw would not. And you have to believe what that dictionary says, because it is really big and heavy, so it must be right.pigtail [elect] A short, flexible wire, usually stranded or braided, used between a stationary terminal and a terminal having a limited range of motion, as in relay armatures.
So that means nobody will ever again doubt anything I say??? Cool! :grin:charlie b said:And you have to believe what that dictionary says, because it is really big and heavy, so it must be right.![]()
charlie b said:I do. This is from the "McGraw-Hill Dictionary of Scientific and Technical Terms":
