Yesterday, I was going over the placement of a recep that is near a hose bib but inside a structure with a GC. The hose bib was in a utility closet that housed a bunch of other mechanical equipment that served a swimming pool. The closet had a floor drain but definitely isn't considered a "shower" because of the other equipment in the space. The hose bib was used to fill a mop bucket and was at about 36".
I needed to place a GFCI Recep and a switch, all related to controlling and protecting the pool lights.
When we were "eye-balling" the placement the GC was like "Oh yeah, you gotta be 12 inches from the hose bib don't you".
I said "Where did you get that from?"
He said that's code.
I was like, what code? Who's code?
He didn't really have a good answer. I told him you can't have a Recep in a shower or tub space.
Other than that I can't find a code related requirement limiting placement?
I feel like good common sense will tell you where you shouldn't put the Recep.
Other than that, you have to use a WR Recep and have the appropriate WP cover.
Anything I'm missing?
State codes don't amend or add to NEC on this issue.
To avoid any conflict I put it more than 12" away (up and to the side)
Thanks!
Thanks!
