Alwayslearningelec
- NJ
- Estimator
I agree. I want to say I believe, in the past, I've actually seen receptacles on symbole list with the designation "SP".I would desccribe it as a receptacle with a unique configuration to allow only a specific load to be supplied.
That would be my take on it too.Could mean almost anything.
It says "special purpose", which I would take to mean any receptacle intended for any specific load, and not just a general use receptacle.
Not right or wrong, but I have the other take on this. Especially since they are asking for voltage, amperage and circuit not what gets plugged in. If it isn't a 5-15 or a 5-20 receptacle, I would engrave a plate.Could mean almost anything.
They said "special use", but just thinking about "why" they would want engraved plates, and I'm thinking they probably meant "specific use".Not right or wrong, but I have the other take on this. Especially since they are asking for voltage, amperage and circuit not what gets plugged in. If it isn't a 5-15 or a 5-20 receptacle, I would engrave a plate.
Which is why I was saying "not right or wrong" I was thinking they want to be easily able to ID the voltage phase and amperage when it isn't a regular plug.They said "special use", but just thinking about "why" they would want engraved plates, and I'm thinking they probably meant "specific use".
For example, just assume it's something like a restaurant. They probably want something so everyone knows "Coffee Pot goes here on a dedicated circuit, soda and ice maker go here, 2 heat lamps go in this duplex....."
If you didn't ask for clarification before bidding the project, you may be in for a disagreement with the designers.
