Around here the owner is responsible for maintenance.
That would be normal everywhere unless something special in the lease agreement specified differently.
His property, his problem, his bill.My Mother would have said "B___ S___ little Eva!"
Only if she is allowed to subtract it from her rent. (Plus a small processing fee.)
Possible.Could also be that a bunch of paint coated the blade on the way into the outlet and the resulting contact area was smaller and overheated.
Why is she even whining? She renting, the landowner will be paying it.The problem with explaining this to her is that she thinks that in general, receptacles are not ganged to each other back to one breaker. Most people don't think it in electrical terms. They see an outlet, and they will add all sorts of things, plug strips, and then even more appliances to said plug strip. Then wonder why the breaker trips. She rented the place and the owner wants a licensed electrician to check it oiut, and she is whining about it.
Landlord wants her to pay.Why is she even whining? She renting, the landowner will be paying it.
What does the landlord allege the tenant did wrong to cause it?Landlord wants her to pay.
That's damage from a long-duration high current, like a heater.
Not illegal, unless specified in the rental agreement.He probably thinks she used a space heater or something.
All of which is the landlord's responsibility; I presume you agree.I don't know of any way to prove it but I would bet on a poor connection. Anything from poor spring tension to maybe paint on the connection.
In the lease we have with the tenant they cannot have a portable heater.Not illegal, unless specified in the rental agreement.
It is in our lease.All of which is the landlord's responsibility; I presume you agree.
And dime-store receptacles that pass current through the spring elements.Low spring pressure is often a problem with older receptacles where they get constant plugging and unplugging.
A device that cost 25-30 cents probably won't last forever.
You mean backstabbed?And dime-store receptacles that pass current through the spring elements.
