shortcircuit1
- USA
Hello,
I have two questions on receptacle spacing.In the attached PDF's you will see the highlighted areas where i have a question on.In the first markup when you enter the bedroom i placed a receptacle with in 6' of the door and then i should space it 12' from that.But as you can see there is a break in wall space cause of the entry into bathroom.Do i need a another receptacle with in 6' of the bathroom door?If thats case then i need tow receptacles in that highlighted markup?
Second PDF question:
This is a Living/Dining room.They have a WH/HVAC Unit...Do i need a receptacle with in 6' of that door.Yes there is a window and that is a fixed window.So that counts as a wall space and i need to put one?But as you can see i already have another receptacle near the dining table so if i count 12' from that i am okay..But from the closet door i still have to put one?
