Receptacles burning
I have seen 240 applied to a GFCI receptacle, it goes pop and the smoke comes out.
No fire. Doubt UL would list them if a predictable overvoltage made them burst into flames.
We could speculate as to what's popping - is the resistor only rated 120V or is the coil failing, etc.?
But I'd lean towards it being an inherent safety measure. Think of all the damage from 240V running through electronics (we've all seen that smoking television) when a neutral is lost. I'd rather "pop" a GFCI than smoke a $1,000 tv.
But in many cases you likely get to pop the GFCI and smoke the TV at the same time.
duplicate the occurance..
Get an old gfci receptacle and a lighter take them to the owner, then show him how the damage was made.
Bust open the original damaged receptacle and show him that there are no burn marks on the inside.
Night light
Night light
I just had a night light mark the GFI ,the wall plate and wall behind it, not as bad as that. My wife tapped it because it did not work and shorted the filament, it still worked for days till she showed me the wall, and I ripped it out.
