stickboy1375
- Litchfield, CT
you've never seen someone plug an extension cord into an outlet before? I dont care where the receptacle is located, a homeowner will make it work.... thats my take on why the code is what it is....
bstoin said:In all my years of doing remodelling and electric work (more than 20), I have NEVER seen anyone fail an inspection because a freezer, refrigerator or similar appliance was not ground fault protected regardless of the location. I can genuinely say that I have also NEVER seen a fridge in ANY kitchen-old house or new-in Ohio, South Carolina or Florida (all of which I have worked in for quite some time) placed on a GFCI.
In fact if you look at article 210.8 it is quite clear that there are exceptions to GFCI placement and usage requirements such as: those not readily accessible, single receptacle used for appliance, etc.
Of course, your right in that people have died from certain electrical accidents such as I had mentioned in my previous posts, but there is absolutely nothing (that I have seen in the code...correct me if I am wrong) that says a fridge or freezer HAS to be on a GFCI.
An AFCI most likely would have prevented this fire but I don't think the code will ever change to the point that every outlet in a house sould be AFCI and/or GFCI protected.
lwood said:use a dead front gfi outside the access of the crawl space to feed the receptacles.
680.51(a) submersible pumps gfci protected
winnie said:It seems silly to me that a non-GFCI receptacle would be permitted in an unfinished basement to feed these loads, but would not be permitted in a crawl-space where it is even less likely to be used for an appliance other than the one intended. I'd give odds that the CMP simply missed applying the same exceptions to crawlspaces as are applied to basements.
Why do you think that? Even the manufacturers of that device say they will prevent only about 40% of the fires that start in the building's electrical system.An AFCI most likely would have prevented this fire...
