Read this: http://forums.mikeholt.com/showthread.php?t=128936What is a good rule of thumb between recessed lighting in a residence with 65 watt lamps?
This is most bull i'v ever seen for some one wanting a rough in for can lights . I posted one of those you told him to look at and never got a straight answer. Come on guys were are talking common situation, 8 ft ceiling , 6 '' cans , contractors normal reg trim. I will answer his post with 24 '' from walls and approx 6 ft max spacing . it doesnt do any good to say you have to divide by the room size the answer is 6 ft or less spacing, we have no way of knowing if a customer will install spot or flood bulbs. It usually never works out exactly 6 ft so the space will be less and that is better. i have put them on 7 ft with no complaints.
I have to disagree with you jetlag. 24" works fine for kitchens or areas where you want to highlight pictures, etc but in a family room things could be different. First off you need to know what the customer wants to accomplish.
Generally, lamps will handle perimeter lighting so I tend to move the lights out to 36" - 42" off the walls. Spacing apart- I would say about 5' but it depends again on what is being accomplished.
Also if there is a fan in the middle of the room one must mae sure not to get too close as you will get a strobe effect. There is aot to think about in laying out cans.
In a dining room we may have a chandelier in the middle and 4 cans in the corner of the rooms. There is no simple answer as each room may be unique.
Pretty bold statements considering you own lack of knowledge regarding can installation.
http://forums.mikeholt.com/showthread.php?t=128861
http://forums.mikeholt.com/showthread.php?t=128912
http://forums.mikeholt.com/showthread.php?t=128962
I have probably installed more cans than you in 40 yrs but wanted to get some expert opinions but it didnt happen, I'm back to what I already knew , not a single reply I could use.
A lot of people tried to help you out in your many threads, you just spit in their faces.
Well youre welcome I guess. :roll:
All the advice you were given was useful and accurate. The fact that you don't agree with it doesn't change that.
You should be barred from the forum for statements like that. I can disagree with anybody I want
