Installing LED tape for undercabinet lighting.
Here's the equipment I'm using:
-5 runs going to basement below kitchen, about 12 feet each. 16/2 CL2 wire
-1 run going from backsplash switch to basement. This can be HV or LV
12v LED Tape:
SMD3528 4.8w/meter
-or-
SMD2835 12w/meter
Driver:
Class 2 12v 45w or 60w dimmable driver
-or-
Class 2 12v 45w or 60w non-dimmable driver
I have a couple questions here:
1. What is the standard and preferred method of installing a switch? HV or LV side?
Install dimmer switch on LV side of driver:
Pros:
-Possibly cheaper driver
-Easier to install RGB controller later
Cons:
-Increased distance of circuit, increases voltage drop
Install dimmer switch on 120v side of driver:
Pros:
-Possibly cheaper switch
-Less voltage drop on LV side
Cons:
-Expensive dimmable drivers
2. Does anyone have recommendations for dimmable drivers?
Armacost has a 45w dimmable driver I'm unable to find their 60w driver.
I'd need to buy multiple drivers if I went with the newer SMD2835 LEDs.
12v LED Tape:
SMD3528 4.8w/meter
-or-
SMD2835 12w/meter
Driver:
-or-
Pros:
Cons:
Pros:
Cons:
