- Chapel Hill, NC
- Retired Electrical Contractor
I ran across this article. Is this for real. It comes from this site--- http://batteryaz.com/how-to-recondition-batteries/
Laptop battery reconditioning is more than just possible and there are a lot of different ways to achieve that, but some of them may be time consuming. In any case, it is the best choice to try simply because a new laptop battery is expensive and it may cost more than a new laptop.
On the other side, all of these ways are simple and you can do them by yourself. Laptops that have removable batteries are much simpler to do this, but you can try these steps on laptops with non-removable batteries.
In addition, do not use these solutions on a new battery, simply because this will have a negative effect and they will get damaged. In any case, you can recondition an old battery and you will be able to use that laptop for a lot more time. The best part is that all solutions cost nothing.
Solution 1
If the battery is not leaking, there is no acid around it, this way will be successful. In any case, you will end up with a new battery that can last for a long time. In addition, you can repeat the procedure a few times.
- Remove a battery from your laptop and place it is a plastic bag.
- Place it in a freezer and wait for 12 hours. Then, remove it from the bag and clean it.
- Place it in a laptop and fully recharge it.
