earshavewalls said:The higher and stronger tension is part of what makes a hospital grade receptacle just that. Equipment is constantly plugged and unplugged in these devices and, as stated, the tension must be maintained for all of the types of equipment being used.
480sparky said:
weressl said:So why don't they just standardize on twistlocks?
M. D. said:pretty neat,...do all attachment plugs have a standard thickness to the blades?? and,.. are they the same as that which is doing the testing ? or are receptacles designed to accept a varying degree in the thickness of the blades for attachment plugs??
480sparky said:I'm sure they are all the same size. Otherwise, some plugs will easily fall out, and others won't fit in at all. Probably someone will post a link to some NEMA standard.....
M. D. said:Ask ,and ye shall receive:smile: Thanks for the link
480sparky said:Seek, and ye shall find. Knock, and it shall be opened unto you.
Matthew 7:7 Ask, and it shall be given you; seek, and ye shall find; knock, and it shall be opened unto you:
For every one that asketh receiveth; and he that seeketh findeth; and to him that knocketh it shall be opened
mdshunk said:The last time I quoted the Bible, the post got zapped. Go figure.
