Re: red sticker
Hiram,
230.2 essentially says, as a result of your new work, the new larger service you've installed, that the installation has to be done in such a way that the occupancy has one service drop to it.
So, since no work is being done to the other service, the new one has to run over to the PoCo drop supplying the unimproved service.
This can be a headache to work out, contractually, if the two halves of the occupancy are under different ownership (like if they are condominiums, or worse yet, owned together by two family members that are at odds with each other - did that job once).
