I'd be inclined to look at the plug supplied. probably its a std 115V plug (for USA use). The 200-240V spec probably means it is rated for both common household voltages found in the world (115 and 220).Originally posted by freddie:
If the servers for example specifications says input voltage low range min. 100v, max. 127v and on the high range min. 200v, max. 240v what type of connection should be used?
If you are using a 240v supply to the servers should the outlet be a 3pin or a 4 pin?
