I think it's just an all-around, bad idea to have 240V lamps w/screw bases. What's to stop Joe HO from wiring one to his 120/240 system?ramsy said:Perhaps a grounded 480/240 Delta.
ramsy said:"In the mid 80's, I lived off base near Bitburg where the natives seemed well prepared for human nature, and for enjoying or disciplining that nature in moderation vs deleterious excess. If they are accused of being pagans, it is for including Mother Nature in the holly Trinity, and indoctrinating themselves with it".
Sounds like you liked it over there, why not go back?
"In this environment installing 240 or 277vac lights, at the brink of disaster, would not deter the pursuit of maxim profit, as long as the screw shell is connected to ground".
I thought that might be what you were trying to point out. However, I suggest you reserve the term "uncertainty" for apparatus requiring high precision.tallgirl said:Lamps aren't high-precision loads.
The variation in voltage drop across a bulb in a network like what you've drawn -- based on plus or minus however many watts a 180w bulb actually consumes under operating conditions -- exceeds the amount of voltage drop needed to change the direction of the current flowing between pairs of pairs of bulbs on the neutral conductor.
Smart $ said:As I said before, the power factor of ballast-driven lighting coupled with the reactance of AC wiring could reduce voltage drop on a circuit (...it could also increase voltage drop, as either way depends on circuit and load parameters).
Nope! Lagging power factor.wirenut1980 said:How could the power factor and load parameters reduce voltage drop? This would have to mean that the load would have a leading power factor, right? What loads have this parameter?
hillbilly said:Indoctrination is a synonym of brainwashing and propagandizing. I'll take free thought and action if you please.
Smart $ said:Nope! Lagging power factor.
Go to NEC Chapter 9, Table 9 and compare Effective Z to it's respective Resistance column values, down to #2. In short Z is less than R. However, circuit parameters will change Effective Z for power factors other than 0.85 and a calculation per Note 2 would be necessary to determine such.
Smart $ said:I thought that might be what you were trying to point out. However, I suggest you reserve the term "uncertainty" for apparatus requiring high precision.
As to your point... I don't think so. I believe the variations in wattage will only change node voltage and the amount of current, but not direction. Let me put it to you in the form of a diagram where resistor symbol direction and position is more indicative of voltage change as a result of wire impedance.
tallgirl said:Consider this -- if you have a pair of 180w nominal lamps and one is drawing 183w and the other is drawing 177w (for an average of 180w -- no great stretch here), what is the voltage at the midpoint of those two lamps with respect to the (unconnected) neutral, if they are connected in series between a 240v supply? Now, if you take another pair of 180w lamps, both of which are also actually draw 183w and 177w, but happen -- just because that's life -- to connect them in series oppositely, what's the voltage at the midpoint of those two lamps relative to the midpoint of the other two lamps?
"Pick me! Pick Me! Me! Me!" ~ Donkey in Shrecktallgirl said:Consider this -- if you have a pair of 180w nominal lamps and one is drawing 183w and the other is drawing 177w (for an average of 180w -- no great stretch here), what is the voltage at the midpoint of those two lamps with respect to the (unconnected) neutral, if they are connected in series between a 240v supply?
In round numbers, there would be a 2v offset for each pair, for a total of 4v.Now, if you take another pair of 180w lamps, both of which are also actually draw 183w and 177w, but happen -- just because that's life -- to connect them in series oppositely, what's the voltage at the midpoint of those two lamps relative to the midpoint of the other two lamps?
LarryFine said:"Pick me! Pick Me! Me! Me!" ~ Donkey in Shreck
Exactly!tallgirl said:Where this is all going goes back to Smart's headache. ...in practice an "ultra-accurate" calculation is impossible.
Smart $ said:Exactly!
I think the ONLY point you are missing is that current direction does not change just because the zero volt point moves, or the so-called midpoint voltage changes with lamp wattage variations.
Consider the above image. The fact is, TP2 can NEVER have a voltage potential closer to L1 than does TP1. Additionally, the only time TP2 and TP1 can be at the same potential is if the L2 circuit is not conducting, for whatever reason. Yes, current can change direction from TP1 to Neutral. Yes variations in lamp wattage will have greater effect as pairs are added. However, the current direction will remain the same from node to node on the neutral conductor.
