Or put it on a dedicated circuit with one receptacle.Fix or replace the refrigerator.
If the receptacle is in a location that requires GFCI protection you still need GFCI protection whether it is a dedicated circuit with one outlet or not.Or put it on a dedicated circuit with one receptacle.
with all do respect, then whats the point of a GFI Test button on a plug tester.The only approved way to test a GFCI is the onboard test button, a plug in analyser is a convenience but will not work on a two wire GFCI. If an inspector turned down a job because his plug in tester didn't trip a GFCI he needs some educating.
Roger
If the receptacle is in a location that requires GFCI protection you still need GFCI protection whether it is a dedicated circuit with one outlet or not. Those exceptions for dedicated receptacles went away some time ago and I don't think any states are that far behind on code cycle they are using.
They work on three wire circuits fine but as with most tools they have their place and limitations. Search the forums for past threads dealing with GFCI testers and two wire circuits for more discussions on the matter .with all do respect, then whats the point of a GFI Test button on a plug tester.
A convenience. If it won't trip then the test button on the device definitely should be depressed to see if it trips.with all do respect, then whats the point of a GFI Test button on a plug tester.
Any leakage that causes an imbalance of 4-6 ma should trip the GFCI.I guess my concern would be if a frig has a leaking/stray voltage to the chassis from a current carrying neutral would the gfi detect that, being that the neutral and ground could have a potential difference. In other words a bare footed person on tile or concrete floor touches the metal frame with the reference of the current carrying neutral could it seek out a path of least resistance through the persons feet. I could be wrong.
Did you buy one? Now you know.with all do respect, then whats the point of a GFI Test button on a plug tester.
Roger I don't have an argument with any of this, I was simply answering a question on post #1. Thank you.They work on three wire circuits fine but as with most tools they have their place and limitations. Search the forums for past threads dealing with GFCI testers and two wire circuits for more discussions on the matter .
Roger
Ok, I guess if it’s within 6’ of a sink or somewhere like that.If the receptacle is in a location that requires GFCI protection you still need GFCI protection whether it is a dedicated circuit with one outlet or not.
I didn't t think you did I was just making a point against an inspector that would use a tool outside it's capability and turn down a proper installation because of it.Roger I don't have an argument with any of this, I was simply answering a question on post #1. Thank you.
FWIW, it provides a way of testing that is not dependent on the internal test button working, as long as a good EGC connectiin is in place to the receptacle.with all do respect, then whats the point of a GFI Test button on a plug tester.
Sorry but it would still trip if current was flowing anywhere besides the grounded and ungrounded conductors. IOWs, if current out added to current in doesn't equal zero the GFCI sees problem.easy quick field test I'd perform would be remove the GFI from the wall keeping it connected ,remove the ground and re plug in the Frig, if it holds then its probably tripping from a fault to ground. Just a though ..
Roger
Can we agree on this, that the GFI has no issue unless the refrigerator is plugged in. , Plug in a drill motor see if it still trips, if so change the NEW Gfi, then go from there. This is becoming a frustrating topic. I just now noticed were talking about a breaker not an outlet ..A customer's refrigerator was tripping a brand new gfci breaker
If you think about it, a shock must occur for a GFCI to trip (in this use).As already stated a GFCI will not necessarily prevent a shock but hopefully it will keep it short in duration.
To determine whether a receptacle is wired to be protected by a GFCI.with all do respect, then whats the point of a GFI Test button on a plug tester.
