Re: Refrigerators and Freezers
Demand factors are not required by the code, they are permitted. If you do not use them when permitted, it simply means the service or feeder calculation will result in a large number than the minimum permited by the code.
For your question specifically, are you actually adding in the connected load of each refrigerator from each room as apart of the total service load? If the rooms do not have permanent provisions for cooking, then they don't have a kitchen. If they don't have a kitchen, then you don't have kitchen equipment.
It would be my take that the individual refrigerator loads in each room could be applied to the general lighting load.
