mcclary's electrical
- VA
What code references are these ?08?? I thought it was ok to exceed the ul listing. In other words if UL states a 75 watt lamp in a fixture, by lowering the wattage you are exceeding ul and code requirements. I am not proposing to change the UL listing per say but under qualified supervision design the BC to only use screw in type LED lamp. 410.120
It's fine to put a 1.0 watt bulb in if you want,,,,you just can't size your brance circuit to the bulb. You size it to the max wattage allowed in the fixture
