arenddr
New User
- Birmingham, AL
Has anyone had experience with asking a fixture manufacturer or contractor to relabel the maximum wattage for a screw lamp holder type fixture to a wattage less than the standard maximum wattage? We constantly run into projects where the architect wants to use a decorative (or cheap) fixture that is only available with screw in lamp holders. However, with the current energy codes, it is nearly impossible to use these on projects. Even if LED lamps are used, the energy code states the fixture wattage must be the maximum labeled wattage on the fixture.
From my research, it does not appear this is a common practice. However, I feel like it would be an easy thing for the manufacturers to put a 20W maximum label on a fixture instead of a 100W maximum. Since the label is reducing the maximum wattage, there should not be any safety issues.
Any thoughts on this?
Thanks
Thanks
