owkaye
- Biloxi MS USA
I'm planning the wiring for a future house and wondering if I can comply with NEC by installing radio- and internet-controlled Sonoff relays at my ceiling and wall lighting outlets?
This means there will be no wiring to any wall switches, and in fact there will be no traditional switches used to control the lighting in the entire house. Instead a wifi- and rf-enabled relay will be installed at each lighting outlet, and these relays will be controlled remotely. This will enable all lights to be switched on and off via several different methods:
1- A smartphone app which has the ability to: (1) switch each light on and off individually; (2) switch pre-defined groups of lights on and off; (3) set timers that turn lights on and off on a regular schedule. This control method will work from any location where the smartphone has an internet connection.
2- Non-traditional "remote control" wall switches that are simply stuck on the walls (with double-stick tape) wherever desired, including typical locations such as near doorways, and in non-typical locations (near the toilet, shower, next to the bed, etc.).
3- Portable key fobs which send a RF 433Mhz radio signal to "flip the switch" at the correct Sonoff light relay.
Other than possible NEC non-compliance, are there any reasons why this shouldn't work?
