Laszlo,
The primary difference between your method and mine, is the lack of the vertical line connecting the state of the contacts. I feel that this extra line serves little purpose and can easily clutter up a drawing, especially where the contacts of the switch/device may be separated by several lines of logic.
Yes and no. It is a question of representation. You already WOULD have the vertical line for the operator itself, so even if there are several lines of logic between the contacts, the operator control line would need to be connected between the contacts, indicating that they are controlled by a common mechanical link. The adjacent vertical lines - indicating the alternate positions - would be just additions to the existing one and since they are dashed lightweight lines, they represent less 'clutter' than the man heavy line itself.
It is a choice. The smart choice - IMHO - is either of the following:
- Do not interject any logic lines within a single device.
- If individual contacts are separated by logic lines, do not connect the operator, but redraw the operator at each separated contact(or group of contacts).
When the swicth is more than just a HOA or Stop-Run-Start, like a drumswitch on crane or other multiposition witch the logic truth table is the way to go. But then one uses relay type contacts, as opposed to push operated type, and all contacts ar shown in the open position. Each contact has a sub-number and in the position matrix and X would indicate which contact is closed in what position. Dash between adjacent X positions indicate that the contact does not open during transition from one position to the other.
