djcrzysounds@yahoo.com
- Scranton, Pa
I was called to a church last week. Here is the picture since my scanner isn't working to give you a picture. Condensate Return Pumps for a boiler. There is an alternating relay (by Furnas) that was not working. Got a replacement from SQ D. Now to the wiring. Low water control wire (240V) comes into enclosure, feeds 2 delay on make timers and then the alternating relay. Each timer goes to one of the pump starters. each side of the alternating relay also goes to one of the 2 pump starters. The new relay will latch in either position 1 or 2, but when there is enough water in the boiler, the control circuit de-energizes but the alternating relay remains latched(electrically held), why doesn't it unlatch? I know the timers are there for 'redundancy' should one pump not work, the other one will turn on after approximately 1 minute(well both will be on but one should already be on)
