- Massachusetts
If the NEC doesn't require it, then the NEC is lacking, in my opinion.
Why? Because "off" should mean off.
So put in a proposal to ask for the change, the NEC does not change on it's own.
To the NEC off means off if it says 'off', as a disconnecting means does.
On the other hand controllers are not the same as disconnecting means and people working on electrical systems should be qualified to do so. Part of that training means understanding that unless you check .... nothing is off.
