jaylectricity
- Massachusetts
- licensed journeyman electrician
Hey all,
I'm looking to add a chandelier to the center of a room. I have recessed lights currently on a switch/dimmer. I was thinking I could remove the switch, tie the conductors through giving me constant voltage at the recessed lights. Then install two remote control dimmers like the Insteon type, and two receivers somehow in the ceiling where they can be powered with what formerly was the load from the switch and feed out to each of the new loads. (4 recessed lights as one load and the chandelier as the other load).
All I'm finding is a controlled receptacle which I'm pretty sure I couldn't hide in the ceiling even if it had a load out function. I was looking at something called a micro-dimmer, but that appears to be added behind a switch still requiring hardwiring of the line and the load from the switch box. I'm not even sure why the words "remote control" are included in the description.
Any help on a solution to my problem or even some basic knowledge on how those micro-dimmers work and what problem they solve.
