Remote Garage Service
howardrichman
I recentely wired a remote residential Garage 25ft. from house w/ two circuits (20Aoutlets, and 15A for lighting). Inspector informed me If I install a panel, I'de have to install two ground rods and a main, sa. a service entrance. I believe if there were only 1 ckt in garage, I could have used a ML panel and no ground electrodes. Since I'm keeping two ckts, I figure the best alt. is to just run a 12-3 UF to the garage and use existing panel as a J-box, and should pass. I'm presently trying to find the code for a remote residential garage.
any here run into this?
Howard...
Howard...
I am a bit confused here-- if you install a panel then you would need no more than 6 handles to disconnect the garage. You would still need 2 ground rods and as of 2008 you would need a separate EGC (4 wires).
If you install a 12/3 UF then it would be considered a single feeder and you would not need a panel nor ground rods but you would need a means to disco the circuits at the garage ( a DP switch will suffice).
Did you actually install a service or did you install a feeder from the existing building?
Assuming you are feeding this from the existing building you would need to read part II of article 225.
Roger
Then how would you feed those two circuits at the main panel? If they're on the same yoke, you would need a 2-pole breaker. 210.4(B).
Try again-- I lost you.
12/3 fed from the house with a DP breaker to the garage. No panel just a dp switch as a disco.
One circuit in the garage is 15, the other a 20. Read the OP.
A handle tie would work for this combination or just get a 15/20 amp two pole breaker. :wink:
Roger
My assumption is that the wire is already run, and I'm assuming both a 14-2 and 12-2 UF. The 14 is on a 15a breaker, and the 12 on a 20.
Using a DPST switch for the garage disco, how do you disconnect both circuits back at the breakers to comply with 210.4(B)?
It would be a violation to have a 12/2 and a 14/2 run to the garage. I believe the op got sited and has to redo the job. He suggested the 12/3 and I agree. Until the op gives us more info I don't think we can keep guessing what he means.
I just realized what you are getting at. I see Roger has already given the answer. 2 sp breakers with a 15 and 20 with handle ties. 12/3 to the garage
Thanks for help! Well I did install a 4/8 ckt ML panel in garage w/a 15, and a 20 amp ckt from garage entering it. I have not run a feeder yet. Inspector assumed I was to wire as standard 4 wire sub panel from house and insisted to add a main and grnd Electrodes. Homeowner wants to save $, and just install a 12-3 UF. I might have problem if both ckts at main panel must break simutanously, and still need a double pole switch. Might be easier to just run a 10-3 UF, install main and grnd electrodes at garage, and be done.
Thanks again; Howard...
