jeff48356
- Livonia, Michigan
Some ceiling fixture boxes in old houses are mounted using a thick metal bar spanning two joists, with the box attached to it. Let's say, for example, the box needs to be removed in order to install a ceiling fan in a bedroom (replace it with a ceiling fan box with brace). If working from above in the attic, what is the best tool to use for cutting the metal bar right along the joists so that the new box & brace will be able to screw to them flush? Would a Multi-Max tool with a metal-cutting blade do the trick?
