busman
- Northern Virginia
- Master Electrician / Electrical Engineer
Need so "real world" help if possible. Need to remove a mogul LB to re-route the conduit (easy to remove the conductors back to a JB). Details follow:
2" GRC
Saltwater Environment (50' from the Atlantic Ocean)
Field cut Threads on the GRC
No apparent Koppr-shield (although required)
Question: How hard to remove the LB. I do have 24" Pump Pliers and 24" Pipe Wrench. I do not have a torch, but could probably come up with one. Do have WD-40. Working VERY remotely from Supply Houses/Hardware stores.
Thoughts? Your experience is greatly valued by me. I do VERY little GRC.
Thanks as always.
Mark
2" GRC
Thanks as always.
Mark
