He didn't cite an article and I didn't think it was that big of an issue to push since it was such a quick and easy fix. But I did wonder about it and looked it up later and never found anything. I just read the article you pointed out and there's no a connector on the dead end pipe would bond anything to the EGC. As a matter of fact it's the same article that said I could have ran the ground exposed if I'd chosen to. It was sleeved in the conduit not ran from enclosure to enclosure. I.e. conduit connected to bottom of panel, strapped along the wall, kick back and 90 through the wall to the outside. Wire comes out and hits the ground rod once through the wall. It was that end he was SO concerned about having a connector on. Quick fix 2 seconds no big deal, but I still do not see the purpose of a connector on the end of a pipe that doesn't go into anything anyway.
