while changing a water heater and cutting out the water lines, i had to remove the electrical ground for the main panel, which was just above the ball valve, is this a problem , to take it off and move it to another pipe close by ?
DJR
you are not an electrician, but it is good to see that you have a concern for doing the proper job.
Since you had to remove the conductor, now you will need to install it to the water pipe within 5 ft of where it enters the building. This "other" pipe you mentioned may not be suitable at all. If you are not sure, ask an electrical friend and I am sure that he/she will help.
Good Luck!
