Replacing 2 single pole switches with 1 Caseta Dimmer & 1 PD-6ANS-WH switch
gears46
New User
Edgewater, NJ
Hi - Quick wiring question. I currently have a two gang electrical box with two single pole switches. One switch controls a light (right switch) and the other controls a fan (left switch). I want to replace the current fan switch with the PD-6ANS-WH (i.e. the PD-6ANS-WH non-dimming switch) and the other single pole light switch with the Caseta dimmer (P-PKG1W-WH-R). When I look at my current wiring setup, I am not sure which wires are hot and which are the load wires. The image on the right below shows my current wiring setup and it looks like I have 3 hot wires (not sure though). The switch on the left (in the right image below) is the current switch for the fan, the switch on the right is for the light. The switch on the right looks like it has 2 hot wires connected to it (i.e. the two screw-terminated connections on its right). Presently, all three ground wires are terminated together and separately all three neutral wires are terminated together.
Image on the left shows the fan switch (and its wiring) I am looking to install (green = ground, red = load wire, black = hot wire, white = neutral, blue = 3-way connections).
How should I wire those three (which are presumably hot wires) to the two Caseta Wireless switches I am looking to install?
Any help is greatly appreciated.
I'm sorry but you seem to be way over your head on this and could turn out bad.
With that said:
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
If I have misjudged the situation, if for example this project is related to your work, then send me a Private Message. If you can show me that I am wrong, and that you are a licensed electrician (or at least a licensed apprentice), then I will reopen your post, and offer an apology for the delay and inconvenience.
A reminder to all members, if you see a questionable post, feel free to report it by clicking the
button at the bottom left corner of the post.
