B
bthielen
Guest
Re: required circuits ???
Thanks, Charlie. I could see that as a contractor some codes require what seem like unnecessary extra work. As you suggest, this will not likely be used as it is intended due primarily to its location but, to satisfy the requirements of the code it is necessary. From a contractor's point of view, it is not all bad because the cost is worked into the project. From a home-owner's point of view it is very much unnecessary expense. At least it would not be a totally useless receptacle since it could still be used for other purposes.
Thanks,
Bob
Thanks,
Bob
