mtbtim
New member
- California
Hello,
My name is Tim and I'm not an electrician. I'm doing research on a fire tragedy that happened in Kentucky in 1977. My research deals with building code and fire code violations in the building that burned killing 167 people. One of the documented violations was the use of aluminum wiring that was not run in conduit. I did some research in the California Electrical Code book and could not find the section that deals with this.
The building type was an Assembly Occupancy (A-2).
If this building was brought up to current NEC standards, would aluminum wiring be allowed, and would the wiring have to be run in conduit through the walls? If aluminum wiring is not allowed and conduit is required, could you please cite the sections dealing with these requirements.
I would appreciated any help.
Thanks,
Tim
Thanks,
Tim
