meternerd
- Athol, ID
- retired water & electric utility electrician, meter/relay tech
OP question was if it's required by Code. Conversation evolved into whether it's a good idea. Opinions seem to be both ways. My reasoning that it's OK is that OL's usually trip due to overload. Shorted turns must be rare. I've never seen failures that didn't involve sparks, smoke and eventually a tripped breaker. Just me, though. Main reason we allow operators to do it is because there are only two electricians and both live 50 miles away in Reno. An after hours electrician callout involves 2 hours double-time minimum (per contract). The on-call operator who finds a motor not running first tries resetting the OL. If it resets and the motor starts back up, then they watch flow rate for a bit and if all is well, they go on about their business. If not, they switch to a backup pump. Electricians may go out the next day on regular time if it's a frequent trip on the same motor, but usually it isn't. Calling out an electrician, waiting an hour for him to show up and then finding no problem but paying 4 hours worth of wages is not popular with management and we don't see it as a safety issue. Real world.I'm certainly not either- that would be totally irresponsible. My notices were, in my opinion, completely necessary and as direct and succinct as I thought they could be. Just two of them. Yet still got ignored by a hugely experienced electrical guy in the case I cited. Yet, you have suggested providing notices for operators not trained in electrical matters to make a judgement about making an electrical decision? What the overload tripped because the motor has shorted turns? And resetting it causes a fire that burns the place to the ground. No, it shouldn't. But electrical fires do happen. I just don't think plant operators should be placed in the position to make, or worse, be required to make the decision to push that button. Overloads trip for a reason. The operators should not be called upon to be judge and jury and have to decide on what action to take.
