I'm needing to come up with a solution to reslove a problem with some closet lighting door switches.The problem is that the switch leg is on the striker or door knob side.Thanks to the trim carpenter the doors are swinging differently from the plans.At any rate it's got to be taken care of.I have searched for a ball type 120v. normally closed switch to fix this.Can any of you men lead me to a link to help me.All I have found are 12-24v. type for alarms and etc.. Thank you
